SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure.
This sensor is used to know water level in the tube. It is probable
that your model reports the same codes.
It does not necessary means
a broken sensor you must check the electrical connectors and cables as
well as all the mechanic and pneumatic elements like the hose connected
to the sensor.
It is often clogs with soap and other particles.
Good Luck!
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
