Washing Machines Logo
Posted on Dec 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Neff washing machine with Error code E06. Model no 22052 Please can you let me know what the fault is Regards Justin Posner
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Dec 10, 2010
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620790
Points
5972
Error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced but first check to assure that nothing is stuck inside the pump or one of the lines goiing to the pump they are not expensive if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
1helpful
Cause of Neff Induction Hob Error d4?
I can only confirm that the is no D4 Error shown anywhere. If Neff, the maker can't tell you what the error is, then surely no-one can. Very poor show. I think I would be cutting my losses and go back to a traditional cooktop from a different maker and pursue a legal case against Neff. They should change their name to 'Naff'.
NEFF appliances are among the most durable and reliable kitchen devices on the UK market. But every once in a while, a NEFF appliance will throw an error code for you to deal with.
When a fault code is displayed on your NEFF appliance, it indicates a problem, but not what that problem is or what has caused it. An appliance fault code simply detects and indicates the nature of the issue and provides the general area where investigations need to be carried out.
Bear in mind that on many occasions, your NEFF appliance will be in need of professional repair from a certified electrician to get guaranteed results.
So, if :
  • You have a problem with your NEFF appliance
  • You want to know what a specific error code means
  • You want to trace and correct faults in your NEFF appliance
Then, read on.
NEFF appliances fault codes and their importance Your NEFF appliance will indicate an error code if it has a problem. This will be shown on the digital display and will be a single letter followed by one or two numbers. You can use this appliance error code to help identify where the problem is occurring. The most common appliance fault codes are related to defective oven elements, drainage issues on washing machines, and blocked pumps in dishwashers.
A detailed look at NEFF appliance error codes
NEFF induction hob error codes The most common faults of a NEFF induction hob are:
  • The hob not starting up;
  • The hob shutting off during cooking;
  • The hob flashing after finishing cooking;
  • The hob making a noise;
  • Food isn't cooking evenly.
NEFF induction hob error codes that may help you locate the source of the problem are shown here:
  • F1 - Tnsuitable cookware is being used, or there's no cookware in the zone;
  • F2/F02/F4/F04- Tour appliance hasn't cooled down completely;
  • F8/F08 - If your hob has been working on high power for a long time, the timeout will activate;
  • E9 - There's an internal fault with your appliance electronics.
Bear in mind that most of the issues will require a certifed induction hob engineer to complete the job and fix your NEFF appliance.
Feb 03, 2022 • Neff Ovens
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 • Dryers
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
2helpful
2answers
Washing machine not draining the water
the weater pump is bad replace....
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
1helpful
Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Top Neff Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Eric
ADMIN Eric
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
