Copystar CS-1650 All-In-One Laser Printer Logo
Posted on Dec 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a cs-1650 for which I do not have the software to load on a new computer.
Duane Wong
Level 3:
  • Copystar Master 6,826 Answers
  • Posted on Dec 10, 2010
Duane Wong
Copystar Master
Level 3:
Answers
6826
Questions
6
Helped
2862118
Points
20234
  • Duane Wong
    Duane Wong Dec 10, 2010
    The above link goes to the drivers for Windows 7 and below.
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Unable download software for printer CS 1635 Vista basic
Hi!
Here is the file or click the url... and save the file automatically from your computer..
1. CS 1650 printer driver.
2. http://usa.copystar.com/americas/jsp/upload/resource/17858/0/1650VUP1.exe
Much appreciated if you rate this solution..thanks..
2helpful
I have a copy Start CS 1650 with the error code C-400 any Ideas
there is no C400 code, but there is a C4000 and its a pretty common code on these boxes. it's pointing to your laser unit. definetly not easy to get to. you will have to have laser unit replaced or sometimes i have had luck pulling out laser, pulling polygon mirror out and lubricating the shaft. that only works about 50-60% of time however and if you are paying a tech to do this work, you may just want to replace it as it is fairly time consuming to get laser out.
hth,
razors
2answers
Error 3100
turn it off then re do the process
Reset Scanner Password for Copystar CS-1650
yes you can !
turn OFF the copier and unplug the power cord and the network cables!! Take off the scanner board - there is a jumper to reset the scanning system to default factory settings. Install the scanning system and power the copier. Wait till is Ready to Copy + 2 minutes. turn OFF and unplug the power cable, restore the jumper on the scanning system board. Put it back and power up.
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
