Question about Asko W6021 Front Load Washer
We have an asko 10504 front loader washing machine. It is making a huge noise with whistling sound (like a combination of a jet engine, diesel bus and heavy freight train). It is not spinning out properly. What could be causing this noise? Could it be bearings? Worn belt? Other?
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
Have you checked the pump to insure the filter isn't clogged or debris causing the noise ? Or do you know where it is and how to check it ?
In the event the washer can't drain sufficiently it will not spin properly either. This is by design, but it's easy to confirm or dismiss.
Check as follows...
**Unplug the unit from the dryer or the wall which ever scenario applies to your set-up, or turn off the breaker at the home service panel...safety first**
Remove the lower panel with two screws and then you'll see the pump filter/insert as shown here...
Once here, twist the filter out ( make sure you've got some towels, a wet/dry shop-vac or a drain in the floor close by as there WILL be water present ) and check the filter, pump, and hoses to the pump, drain etc. thoroughly for debris.
The filter should look like this...
Let me know if any of this isn't clear and I'll attempt to help you move forward. Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now try a short spin/drain cycle to listen for whether the noise is still present.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Regards,
Macmarkus :)
Posted on Dec 11, 2010
6ya staff
SOURCE:
My Asko 10504 has started making what sounds like a metal on metal grinding sound when it spins. It's as if the whole drum assembly is moving more than it should and coming into contact with something,...
COULD BE THE TRANSMISSION SPRING OR TRANSMISSION BEARINGS. EVEN UR TUB BEARINGS IN THE TUB, A BAD MOTOR COUPLER HOWEVER U WOULD NOT GET ANY SPIN OR AGITATION IF THE COUPLER WAS BAD. BAD BREAKING SYSTEM WOULD NORMALLY MAKE NOISE BUT WHAT U WOULD GET THEN IS A COMBINED SPIN AND AGITATION DURING SPIN CYCLE,
Mar 23, 2015 | Asko Washing Machines
Machine making loud noises w6863 front loader
could be that the wights are coming loose on the drum turn the drum by hand and see if you can feel any movement in the drum if yes get them looked at also try some oil on parts
Oct 12, 2014 | Washing Machines
Asko w6444 front loader drum vibrating quite loudly. Feet are level. Any suggestions.
Check the 3 transit bolts on the backside of the machine. Should be removed. Could also be a problem with the balancing spring on the top of the drum, so the drum tilts a bit forward, and cause noise
Aug 11, 2013 | Asko W6761 Front Load Washer
My brand new Whirpool front loader 1073DD makes a high pitched whistle when starting to spin and spinning, is this normal?
That actually is a normal sound, The machine is spinning at such a high speed rpm that a whistling noise is a common occurence.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 14, 2012 | Whirlpool Washing Machines
My front loader won't spin - the machine makes a noise when it is supposed to spin but nothing happens
sounds like a bad pump open the sumpm on the lower left side (preapre water to gush out if still in the tub) check if there is any objects in the pump or sump if yes remove and try if not replace the pump
Sep 02, 2011 | Asko W6021 Front Load Washer
Operation manual
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/10504-_E
I think this web site has a PDF of your manual. If not try to googe ASKO 10504 washer manual
good luck
Jan 30, 2009 | Asko W6021 Front Load Washer
Motor not running in Asko 10504 washing machine
The motor might have burned out. Another possibility would be a partially fried control board.
Jan 17, 2009 | Asko Washing Machines
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Oct 30, 2008 | Asko Washing Machines
Asko W6021 Front Load Washer Logo
609 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
