1. To Set Program: Pull up one tripper between hour marks on the 24-hour dial for each 1/2 hour of ON time desired. For example, if timer is to be ON between 12-2 PM, all four trippers between those times 2. To set time of day: turn dial clockwise with the arrow head pointed to the correct time. The dark area denotes PM and the white area
must be pulled up.
denotes AM.
Straight out of the manual. Pull up trippers for all of the time that you want the device to run.
Rotate the time of day dial in the direction of the arrows.
The off/on dial will override the timer until it comes around to the on time again then the timer will control.
Good luck.
Gary
