Sony BDP-S300 Blu-Ray Disc Player Logo
Posted on Dec 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not playing any blu-ray movies - Sony BDP-S300 Blu-Ray Disc Player
Nanny
Level 3:
Genius:
  • Sony Master 2,351 Answers
  • Posted on Sep 11, 2019
Nanny
Sony Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988809
Points
7262
If your Blu-ray player does not play any discs, it may be due to a number of things from cables to settings on your TV.
Your Blu-ray discs may be region coded. Most of the Blu-ray players are region-locked. So you may need to bypass the region code by changing the region code, or a region-free Blu-ray player will suffice it.
Shajan RS
Level 3:
  • Sony Master 890 Answers
  • Posted on May 12, 2011
Shajan RS
Sony Master
Level 3:
Answers
890
Questions
Helped
286182
Points
2593
In most cases, the issue might be with the Java content on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6495&mdl=BDPS300
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
3answers
Ps3 slim blue ray won't play can't find settings
Will it play anything? The laser eye may need to be cleaned. Sometimes the drive will play DVDs but not games, or games and bluray movies, but not DVDs .... in that situation, the bluray laser may need to be replaced
2answers
Blu ray movie wont play
You need a blu ray player to play blu ray discs
2answers
How do i get my samsung c5500c to play my blu ray movies
If none of the bluray movies playing then your BD optical has failed. Get a technician to check the unit phisically.
Samsung BD-P1400 Blu-Ray player will not play movie on my TV
Is the Blu-ray region (on back of box) same as the players region?
if not it will refuse to play it.
3answers
What do I do when trying to play a Blu-ray movie and the following information comes up on the screen? To play this BD you must renew the encryption key. Perform a system software update to renew the...
Have you tried performing a ssystem update? Go to the settings menu and 'system update' should be the first option on the list, then just follow the on-screen instructions
4answers
PS3 will play games but not movies
Well if the regular dvd's dont work.. I would recommend you to buy Blu-Ray movies instead.. PS3 is the best known blu-ray player. buy at least one blu-ray movie and try that.
3answers
Ps3 wont play movies
My PS3 met the same issue. But I have tried to convert the Blu-ray to HD video and transferred to PS3 for playback. Maybe you can do this like me.
Leawo Blu-ray Ripper is an easy-to-use Blu-ray to PS3 converting tool to help you rip and convert Blu-ray file to PS3 videos in only a few simple clicks. The below step-by-step guide would tell you the details on how to rip and convert Blu-ray to PS3 videos with Leawo Blu-ray to PS3 Converter.
Guide on how to convert Blu-ray to PS3 videos:
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
After the conversion is completed, now we should transer Blu-ray movie now in PS3 fridlier video format to PS3 for playing Blu-ray on PS3. Follow the steps below to do so.
Here is a simple step-by-step guide for transferring to or watching video files on your PS3 using a USB flash drive or an external hard drive.
Step 1: Plug a USB flash drive or an external hard drive into your computer and copy over the converted video files that you want to watch on your PS3.
Step 2: After the copying process is done, pull out the USB flash drive or the external hard drive from your computer and then plug it into one of the USB ports on the PS3.
Step 3: Navigate to "Video" on the PS3 XMB menu and find your device, hit triangle to view all contents and select the file you want and either copy it to the PS3 hard drive or just play it directly from the connected device.
By following the guidance above, you can achieve your goal of more safely and conveniently playing Blu-ray on PS3 or watching Blu-ray on PS3 for protecting either PS3 Blu-ray drive or your precious Blu-ray discs from being scratched.
For more details, check: Direct and Indirect Ways to Play Blu-Ray on PS3
2answers
Ps3
try setting the console back to factory settings, i had the oposite problem, would play games but not movies. will it play blu-ray movies or regular? if it doesnt play blu-rays, your disc reader may have gone bad.
1helpful
2answers
Problem with playing
Occasionally the software on most blu-ray players needs to be updated to the newest technology. The reason some discs play and some don't is because the discs that play are most-likely older movies or from a company that still used the "outdated" software. So the discs that don't play (most likely discs made with the updated software) won't play on your player until you've update the player's software. To do this visit, in your case, Sony's website for update info. There are a few ways you can get the info. You can download it directly to your player (if it has online accessibility) or you can request that they send you an update disc. Either way, most companies provide the update for free. Hope this helps, good luck!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
