Hannspree ST42DMSB 42 in. LCD TV Logo
Posted on Dec 11, 2010
Hannspree 42 inch what the code to tune in sky remote
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
723
Points
I found a code after a while searching on the Internet it's 0206 and it seemed to work for me have a go with that and see if it works.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
723
Points
I am having same proiblem sky cant help either. if i find out will let you know
1 Related Answer
Azrael SRL
  • 11800 Answers
SOURCE: Recently purchased hansspree 42 inch
Hannspree is a no-name taiwanese company that uses Hitachi and Toshiba circuits and boards in its devices - monitors and tv's. Because of that it's very rarely supported by other manufacturers. There are only 2 things you can do:
1 - test all the codes for Hitachi and Toshiba, if you're lucky one of them will match. If you're unlucky
2 - the only thing left - do a code scan, maybe a code for another brand will match the commands for the on/off and the volume.
9helpful
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Trying to put volume onto Sky remote handset from HANNspree Tv Remote control No. RC00147P but require the code. please help if you can.
Well you can please follow the below link to get you code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
Thanks for using FixYa!!
Good Luck!!
7helpful
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Re: hannspree 37 inch
i have got a humax 32"lcd idtv.
my sky remote does not find it can i get a code to put in thank"s
3helpful
2answers
Universal code for the hanspree
Please check here for information regarding Hannspree Universal Remote information. Basically, only the DirectTV Big Button remote has the Hannspree codes available.
1helpful
Code
2helpful
2answers
Code for sky remote control
tech guy from ebuyer said no code available but sky remote will work ok but volume and tele on- off facilities will not so use remote which came with television to do this so says he.
Tv fleet scree
programing sky remote control to hannspree tv
Tuning the sky remote.
Phone LG service in Slough, they have the info
Top Hannspree Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
