Question about Nikon D60 + AF-S DX VR NIKKOR 18-55 mm Lens and AF-S VR DX 55-200 mm Lens Including Charger, Lithium batt... Digital Camera
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
    New Friend:
  • 133 Answers
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Posted on Jan 18, 2011
Anonymous
SOURCE:
Nikon 18-55mm lens will no longer zoom to 55mm.
there must be a problem with the lens ring which are fitted inside, occasionally it gets worn out because of improper handling . alignments may have caused you the problem. but once again you need a professional help because you wont get any elements or parts easily except from the company.this lens could also may have jammed due to any reasons, may be a foreign body or so and because the af is OK you are still getting a sharp image up to actual 45 mm which you think to be 55mm. If i were you then I would have inverted the lens and tapped gently and then check it once again or best goto Nikon service centers .
Feb 06, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Hi, can tell to me why my 18-200 af vr lenss go
The "problem" is that the lens has a zoom creep issue. If you are the original purchaser, and the lens is under 5 years old, you may want to contact Nikon repair facilites in Melville or El Segundo to have it checked out.
Some users on forums have claimed that Nikon fixed the plastics ring that contribute to the zoom creep. Apparently, using a rubber band around the zoom ring will minimize the problem.
Hope this helps,
Andrew
May 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
Have nikon 18-200mm lens, after 11months the zoom jambed
This lens has a five year Nikon warranty, if the seller won't fix it, contact Nikon. This lens most certainly should not be doing this!!
Best way to contact Nikon:
800 - NIKON - UX
Mar 01, 2010 | Nikon D80 Digital Camera with 18-200mm...
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Please help! I have a nikon d80 with a 18-135 mm
Ask the players to run slower.
Seriously, there are limits. There's only so much light in the gym, you ISO only goes so high, and your lens is only so fast. A faster lens can get you a stop or two. You can try adding more light. Beyond that....
Dec 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
Lens keeps getting stuck/needs a good tug to zoom past 25 HELP!
Hi Rachael_amor, If the lens will not zoom on the camera will it off the camera? If not then it has some grit, dirt, and the like in the lens. You could attempt to vacuum around the zoom however, I suspect it will need to go in to Nikon. That lens is not well weather sealed, it is a inexpensive consumer lens.
Jun 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
I have a Nikkon D 60 with 18-55. I want to buy a 18 -300 mm AF Zoom lens with VR.
Nikon doesn't make such a lens. As far as I know, neither does anyone else. Nikon's longest zoom range is 18-200mm. Somebody makes an 18-270mm and it is available with a Nikon mount.
Mar 30, 2009 | Nikon Cameras
D40X Telephoto Lens Lock
This has happened to me on two occasions with two different 18-55 lenses. I would call this behavior "common".
Problem: Inside, there are three "rails" that the twist/turn elements of the lens slide up and down on. On the back of each of these rails is a friction material (glued on). Sometimes this will come loose and start to catch as the lens is zoomed in/out. When the lens locks completely, the sliding mechanisms have become derailed or have gone askew sideways and are being forced in a way that prevents movement (hard to explain without your opening the lens and seeing for yourself).
I have attempted repair of my lens by dismantling it, making the repair, and reassembling. I do NOT recommend this! (many small parts that can break easily). Mine worked for a time but was ruined by my inexperience.
DO NOT FORCE THE LENS or you WILL damage it permanently.You should send it in to a qualified technician for repair. I know this may not be the answer you wanted, but it's not worth trying yourself and ruining unless you plan to buy a new one anyway.
Mar 31, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D60 + AF-S DX VR NIKKOR 18-55 mm Lens and AF-S VR DX 55-200 mm Lens Including Charger, Lithium batt... Digital Camera Logo
284 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
