Panasonic Lumix DMC-FZ20 Digital Camera Logo
Posted on Jun 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PANASONIC dmcfz8 Problem: When I turn on the camera and remove the lens cap I get a message on the lens that says "remove lens cap & press button". It seems like the zoom is stuck. We were using the camera for a inside night graduation & was at a distance from the subject that we wanted to shoot. After a few zoom shots we shut the camera off and when we tried to take more pictures the above problem started. Please Help!
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 248 Answers
  • Posted on Aug 05, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
248
Questions
0
Helped
59893
Points
539
Try to help the lens go out by pulling it very very lightly...
1helpful
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Getting lens cap on message push button nothing happens
lens cap means a cap in your camera lens, you have to remove it manually with your hand and not just a push buttons.
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Hi my camera is telling me to...
Is the camera turned on? Removed the Cap on the Zoom lens? Try turning it off and on, while the cap cover on the lens is removed, then press the heart button and take some photos. What specifically is the warning?
1helpful
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Lumix DMCFZ8
I had the same problem after dropping the camera. In my case, the lens became jammed. Of course your problem may be due to something else. In my case, I disassembed the camera and reassembled it and it now works fine. It was a bit time-consuming to do, but is possible.
I used these instructions, although they are for a somewhat different model. http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
In the case of the FZ5, some people reported being able to get the lens to work by manipulating the lens without taking the camera apart. This might work if the cog inside has slipped off of it's track. In that case it might be possible to work it back into place. If the cog is intact, though, forcing the lens might damage it.
LCD showing "remove len cap and press reset button" always
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
