Question about Kitchen Appliances - Others
I have a ballantyne flavor crisp pressure dryer DSS-E9. Changed out thermostat but only heats up to 215 degrees then stops I need to get it up to 300 degrees. what's wrong? Aaron
I need a wiring schematic for a Dss E9 does anyone know where I can get one?? I am following the handy mans switch change and now the contactor wont pull in which I think was priginal complaint. I am not up to speed on the control side of this fryer. Any help will be greatly appreciated
Posted on Aug 02, 2012
6ya staff
SOURCE:
Do a tumble dryer have a reset button once you have changed the thermostats?
check the heating element they might be the problem if they are not getting any power or are open.
Aug 27, 2014 | Hotpoint Dryers
Estate electric dryer
You will need to check the temperature coming out of the dryer when on high heat. It should read around 160 degrees on the high end, and 110 degrees on the low end. If it is cycling before the 155-160 degrees mark, you may have a bad cycling thermostat.
Here is the thermostat to order.
Here is a video to show you how to replace the thermostat.
Regards,
Richard Roth
http://appliancecafe.com
Nov 16, 2012 | Whirlpool Dryers
Our Roper dryer stopped heating. We changed the
check the thermostat and overload (or thermal cutoff) located on the heaters housing...
Jan 15, 2010 | Dryers
98 cad deville is running at 210 degrees
Reverse flush the cooling system and put in fresh antifreeze to -20. (20 below zero). If that doesn't help, replace the thermostat.
Mar 18, 2009 | 1998 Cadillac DeVille
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Coolant issue with 1997 blazer
check to see if you have a leak in your heater core,and if the heater core is not leaking you might have a leak on the intake gasket or the head gasket
Jan 03, 2009 | 1997 Chevrolet Blazer
Engine heating up after turning off
Do the fans on the radiator run when it heats up?
Aug 23, 2008 | 2000 Jeep Grand Cherokee
Kitchen Appliances - Others Logo
389 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
