Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start.
Now next you can do is
If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button.
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reginout to scan for errors.
Try to reinstall the driver from your driver disk which provided when purchased
or download the latest driver corresponding to your model
