Kyocera FS2020D ECOSYS Monochrome Laser  35ppm USB20  Parallel Interfaces 500 Sheet p Printer Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Describe your KYOCERA FS2020D Match envelope Problem the printer is stating MATCH ENVELOPE SWITCHES?
Anonymous
Level 2:
  • Expert 200 Answers
  • Posted on Feb 24, 2011
Anonymous
Expert
Level 2:
Answers
200
Questions
0
Helped
188608
Points
372
Load the status moitor utility and using that you can set the bypass paper size to match the envolpe size you are using.
  • Anonymous Feb 27, 2011
    I have follow up information for you -
    Displayed when either of the envelope switches is not pressed. To print on the envelope, press the both switches.
    This is listed in the printers basic operations guide. You can download the operations guide using the below link at the manufactures website.
    http://usa.kyoceramita.com/americas/jsp/...
My printer it showing me match the position of envelope switches
Too vague a question. No 'make model (what it is)'.
Google
make model manual
They are all online. You can use CTRL+F to search for words or phrases in the manual if 'match the position of envelope switches', is in fact an error message and not just text within your question?
Help, fix the error code of Kiyocera Photocopy Machine "match the position of envelope switches"
Previous FIXYA question had two suggested answers:
http://www.fixya.com/support/t6209979-match_envelope_switches_error_message
match envelope switches error message cannot remove it cannot bypass it...
Quoting:
Open the back side of the printer. There are 2 buttons for the envelope. Switch them so that they are at the same position for normal paper. See also manual. It's described there. Posted on Sep 29, 2010
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts Posted on Sep 29, 2010
1helpful
How to fix match envelope switches?
On the FS-4000, this message can be cleared by releasing and pulling out the rear unit until it stops and making sure that the green pressure buttons on both ends of the fuser unit match. Both buttons depressed indicate envelope mode. Both released, indicate normal paper mode.
2answers
Kyocera ecosys printer displaying envelope mode
The message you get is from the fuser setting for printing envelope. At the back of the printer, you have a handle wich opens the back dor. There is located the fuser (fixing unit) that will slide back. On left and right of the fuser, you can see 2 green buttons. In your case one of them or both are pressed. If you press one time, the button goes down. If you press again, the buton rise up. Try to press them down.
2helpful
Match envelop swiches how i can fix it
To turn off envelope mode open the rear door and slide out the Fuser on top you will see 2 green push buttons push them to realease and machine should be out of envelope mode
1helpful
2answers
The problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
the problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
68helpful
2answers
"match envelope switches" error message. cannot remove it. cannot bypass it. printer is unusable. urgent. already down one entire day, students (and myself) are climbing the walls. Thank you for any...
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
