Freezers Logo
Posted on Jul 31, 2017
I have an Amana Refrigerator model #TX20QBW that is dripping water from the top freezer into the Refrigerator. I solved this problem on our basement fridge by defrosting the freezer. On that fridge there is a bottom panel in the freezer that was easily removed so I could access the ice and water build-up. I can not figure out how to do this on the TX20QBW model. Any suggestions for opening it up? Thanks!
5 Related Answers
Anonymous
  • 447 Answers
  • Posted on Jan 01, 2008
SOURCE: Up right Amana Deep Freezer
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
Anonymous
  • 417 Answers
  • Posted on Feb 16, 2008
SOURCE: Zanussi refrigerator
make sure that the fridge temp control is not set too hi also check that the drain away at the back of the fridge is clear.
Thanks J
MARLON KELLER
  • 111 Answers
  • Posted on Jun 01, 2008
SOURCE: defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Anonymous
  • 13 Answers
  • Posted on Jan 21, 2009
SOURCE: auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
Cleverer2
  • 298 Answers
  • Posted on Mar 26, 2009
SOURCE: I'm getting ice build up at the top of my Amana upright freeze.
This means the seal at the top is not tight and air is leaking in.
There are 3 possible fixes:
1. Loosen and Rehang the door so that a piece of cash-register receipt paper cannot easily be pulled thru the seal when the door is closed (all the way around) get someone to help. Dont take the door hinge screws out, just loosen them, push the door in to compress seal and tighten them again
2. Replace the seal ($12-30.00) - Take make, model and serial number of the appliance with you to eliminate a return trip.
3/ Treat with Armor All to make gasket seal soft again (2-3x) and give it a wipe all the way around with Vaseline.
Whirlpool refrigerator with top freezer
If there is an ice maker in the freezer, look to see if the water is coming from there. If it is then replace the solenoid valve where the water comes into the back of the refrigerator.
3helpful
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
I have water coming from the top of the refrigerator onto food.
sounds like you have a whirlpool/kitchenaid freezer top model. these very often get a clogged defrost drain, that clogs with ice, nothing more. the simple fix is to turn the unit off for 24 hours, open both doors, blow a fan at the freezer, to melt the ice in the defrost drain. The problem however, wont be fixed, the drain will eventually clog up with ice again, until you get a repair service to install a drain heater. But you will have dry lunches for a while, be it weeks, or months?
Mar 23, 2010 • Freezers
Amana upright freezer leaks water on floor instead of in drip pan under it.
check the flor of the freezer if it is caked with ice your defrost drain is clogged
if not
take off the back panal
under the machine follow the drain tube
to the drain pan clean out your duck bill and make sure the tube is in the pan
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 • Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 • Freezers
4helpful
Frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Freezer not cold water on bottom of freezer how do i fix this is a ge model with freezer on top
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 • Freezers
Refrigerator
hi thanks for the question it looks like you have a drain problem the drain tube goes to the back of the fridge by the compressor it is clogged up clean tube thanks te appliance doc
Sep 26, 2008 • Freezers
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Amana Freezer Expert? Answer questions, earn points and help others
