No display
The Viewsonic VG1921wm monitor uses the same power supply board that the Optiquest Q19w uses. When that monitor has display problems like you are having the most common cause is bad capacitors on the power supply board. When the capacitors go out the power board does not put out the correct voltages to drive the back light circuits and the driver circuits so you get no display. There is a very good chance that this is the problem with your unit and it would be worth having a look at the power supply board. Here is a link to a repair guide for the Optiquest monitor and since they use the same power supply board it should help you check you board and show what needs to be replaced to repair it.
http://www.ccl-la.com/blog/index.php/how-to-repair-a-optiquest-q19wb-monitor/
I hope this helps.
