Try this.
1. Do a RESET on the hand controller.
2. Reenter your Site, Date, and Time.
3. Calibrate Motors
Now see if that fixed it. If not it will need to be returned to Meade because a gear or circuit is broken inside the scope.
If this does not work or you cannot RESET the controller then either the DEC motor is fried, or the circuit board controlling the motor has a burned out component. Only Meade can repair this-- or you can disassemble the DEC fork arm and look inside and see what is wrong.
If a gear is broken-- only Meade will have the gear. You will most likely send it back to Meade and let them fix what is broken.
