The dang thing wont spin to ring out clothes. it will wash, then drain but all it does in spin mode is hummmmmm... i have replaced both main boards and checked for if something was clogged i ddint see anything what else could it be or am i not looking in the right spot? it does fine on the test mode .. it spins fast on the test mode . so i cant figure out why it wont do it in the cycle mode?? someone help me .. wont buy frigidaire again.. My Frigidair Affinity front loading washing machine is 2 1/2 years old. It will not spin when the machine is loaded, but will spin when empty. Any suggestions on what could be the problem?
First of all check the motor.most probably its got weak so its spinning when empty but not spinning when there are clothes in the machine.
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Problems
related..
Washing
Machine
Front
Load Washing
heatman101
my washer will go through all the other cycle but when it comes to spin cycle it just wont work. the door is locked hose is not kinked water does drain just wont go to spin cycle.
my washing machine won't spin fast either.when i go through the troubleshooting and do the test it spins fast fine.
My washer drains but then will not spin. Any suggestions?
