Anonymous Posted on Dec 14, 2010
I have copier gestetner 1312, i want to reset it to factory default all i know is to go to " memory all clear" but my problem is when, i set it to memory all clear, ... wat will be my next step to do... i know its like aficio 450 u need to run the Ld calibration...but in my gestetner 1312 i can't find the LD calibration..need help pls
Anonymous
Level 1:
New Friend:
  • Contributor 62 Answers
  • Posted on Dec 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
62
Questions
0
Helped
13044
Points
73
Yes you you have to do memory all cleare-thanks
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
How to reset to factory default for di450/550
Service Mode memory clear, or clear access codes?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
Gestetner 1312 how to clear sc541
Replace the thermistors on the heating unit. Tere are 2. Replace them both.
Memory is full
call an expect to fix hard drive on the machine and this problem is over
User code
SP 7810 Acces code clear.Resets both the key operator code and the weekly timer code.key operator code for OFF setting.Press START to reset.
2helpful
I have a gestetner 1312 copier it says reset pcu proprly.what does this mean.
The PCU is the drum unit. It probably has just worked loose. Just unlatch it and shove it back in to make good connection in back.
6helpful
2answers
HOW TO FACTORY RESET THE SETTINGS OF AFFICIO 2035 E
Hello sir; You have to print out SMC list before you clear all memory then to reset, the procedure as follow;
1, press "clear mode", "107".then hold down "clear/stop" key.
2 enter 5990 press enter.
3, touch on screen "execute".
after print out go backto clear memory.
4, enter 5801-1
5, follow the list to reset each item.
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
