Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
Testimonial: "Excellent!, It was the solution. Thanks!"
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
