HAVE A FRIGIDAIRE WASHING MACHING GLTF2940ESO MODILE MY FWIFE SAYS THAT IT LOADS WITH WATER TO START WASHING THE CUTS OFF AND THE WATER DRAINES INTO THE STACKABLE UNDER THE WASHER COULD THE HOSE CONNECTION BE OF ON THE NINSIDE OF THE WASHER OR CUT OR HAVE A HOLE IN IT
Re: HAVE A FRIGIDAIRE WASHING MACHING GLTF2940ESO MODILE...
Check your rubber boot around your washing machine door it may have a tear in itReplace the water valve. May be It is bad. Please rate my answer fairly and Support me With Regards and Season's Greetings Deepak Richard
Hellow mariadjmaria - So I may further assist you more accurately, could you clarify what the issue is? Are you speaking about a top load washer and are you referring to the top of the agitator?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
E10 code indicates there is no water supply.This can be confirmed by :
Shut off the faucet to stop water supply to the washer.
Disconnect and pulling the supply hose off the washer to confirm the E10Code
Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the
cold water hose and check to see if the screen on your washing machine
is clogged. If the screen is clean and the hose has good pressure then
you will need to replace the water valve on your machine--- this is the
piece that the hoses directly connect to.
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
