I will make two comments.
1- make sure you have backed everything up you want to keep :-)
2 - a hard disk will appear to slow down as it fills up. it is actually running at the same speed but must work much harder to find space to place your data. if your disk is past 70% full you will probably notice a performance hit - if its past 90% full you will see a major hit. if it gets much more than that you run the risk of having real problems.
whatever the cause of the problem, the first thing you need to do is back it up. then make sure its not over loaded and if it is just get a larger drive. get your data over to the new drive and off you go.
SOURCE: Quantum Fireball Lct20 20 GB
Appreciate the direct "Ask Me".
A 20Gb Quantum Fireball LCT20 could be nearing its life end considering the length of time it has been in service. Perhaps what could be done is to perform a burn-in test on the 20Gb HD attaches as a Slave or Secondary on a 2nd PC or alternately, as an external mass storage device through an IDE to USB adapter. Burn-in test would be a multiple time scanning fro errors as those used by Norton Disk Doctor. Alternately, you can also Partition Magic to partition/format and eventually test the HD.
In your concern of PC slow down after 10 minutes, it is possible that:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
SOURCE: aneed to manually add the
Hello, Follow the bellow links,
BIOS SETUP BOOT CD
YouTube - Acer aspire 5580 Main Unit Disassembly.flv
Repair4Laptop: Laptop & Notebook Repairing, Upgrading and Modding Guides: by Manufacturers
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Laptop Parts 101
CD-Rom support from Bios
Phoenix BIOS setup and help
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
SOURCE: Preciso identificar heads, sectors, cylinders de
run the chkdsk utility
i have found the easiest way for me of doing this is to
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive also download and run a registry cleaner cc cleaner is 100%free
http://download.cnet.com/ccleaner/
hope this helps you
