SOURCE: RE:removeal of filter
some filters just pull straight off, while others have a large plastic knob that unscrews to remove the filter. if it is a foam filter, it is just a stretch fit and pulls off, though it usually tears.
J
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
SOURCE: Should I remove the filter when using it as a wet
Absolutely remove the filter for wet vac. Also, if your present filter got wet replace it as the pores are now clogged and you can't save it. J.
SOURCE: How do you remove the filter from Rigid wet dry
Unscrew the 'tab/nut' at the BOTTOM of the filter and pull off the filter cartridge
