You should find +/-15 volts and +5 volts as well as the phantom power... but that light can come on at much lower than desired voltage.
Note that the regulators are current limited so a short on the mixer board can kill one of the voltages.... but you are not getting any input from teh switching portion of the regulator so the switching part of the supply is apparently dead. To replace the supply you would have to call Behringer at 1-425-672-0816 to get the part number and an incident number and then call FullCompass which is their part distributor now.
When working on a switching power supply, use an isolation transformer for safety and use a 60 watt lamp in series with the power cord to limit current during testing.
The circuitry will be SIMILAR to the power supply found on page 9 of schematic you can download at:
http://elektrotanya.com/behringer_ub1204fx_pro.pdf/download.html
SOURCE: i want a labelled diagram of behringer 2442fx mixer
Here: http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
SOURCE: My Behringer XENYX 2442FX Mixer does not power up,
You should find +/-15 volts and probably +12 volts an +5 volts as well as the +48 phantom supply. If only one of these is missing, check the regulator for it... most are three terminal regulators. If the one that is missing has a hot regulator you have a short someplace and this requires skill to locate Probably the fastest way is to use a thermal imaging camera... however I have often used a millivoltmeter to find where the supply drops tpo near zero. Using a "calibrated" finger and search for a hot component on the circuit board can be very effective. Likely one of the surface mounted chips has shorted. Replacing these requires skill so best leave board repair to a skilled repair person as you can easily damage the board permanently.
