Question about Kyocera FS-1016 Printer
Kyocera fs 1016 mpf printer error service call 6400
  • Kyocera Master
  • 525 Answers
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
Posted on Feb 21, 2011
  • somiyamahi Jul 11, 2013
    sommiya mahi
    New Friend:
Je demander la solution des erreurs 6400 kyocera 1116
mercier
Posted on Mar 21, 2015
6ya staff
SOURCE:
1116 error 6400
Remove and reinsert the two connectors of the fuser unit. If not, then remove and reinsert all the connectors from the engine pwb and the power pcb.
Jun 03, 2014 | Kyocera FS-1016 Printer
Service call 6400
Buenos dias no se que hacer cada que doy a imprimir me sale error call 6400 llame servicio tecnico, a que se debe y que puedo hacer
Oct 04, 2013 | Kyocera FS-1016 Printer
Errore service call 6400
Shows as a fuser error (zero cross signal error)but we see this being the power supply and/or bad power to the unit. Check your power outlet (it should be on a separate or dedicated plug with no other devices). Remove and re-seat the drum unit and DV unit. Could be the fuser but if it comes back its the power supply
Sep 30, 2013 | Kyocera FS-1016 Printer
Error call service 6400
Shows as a fuser error (zero cross signal error) but we see this being the power supply and/or bad power to the unit. Check your power outlet (it should be on a separate or dedicated plug with no other devices). Remove and re-seat the drum unit and DV unit. Could be the fuser but if it comes back its the power supply
Service call 6400
HOW DO I RESET ERROR C6400 FOR OLIVETTU D-COPIA 18MF
Aug 21, 2013 | Kyocera FS-1016 Printer
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Tengo una kyocera 1016 sale error call 6400 como elimino es problema por que nesecito solucion gracias
Code: 6400
Contents: Zero cross signal error
input within 3 s.
Causes:
- Defective the power source PWB.
Feb 09, 2011 | Kyocera FS-1016 Printer
Kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Feb 02, 2011 | Kyocera Mita Fs-1016 Mfp Multifunction;...
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1016 Printer Logo
2,620 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
