HP PSC 1315 All-In-One InkJet Printer Logo
Posted on Jul 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not responding to PC instructions to print data
Paper checked, OK. New ink cartridges installed.
Display keeps showing "E' with flashing "check paper/check cartridges".
Prints alignment sheet but keeps telling me to align even after I've printed test page and pressed scan button.Scan button doesn't respond.
Anonymous
Level 2:
Novelist:
  • Expert 106 Answers
  • Posted on Jul 05, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
106
Questions
0
Helped
54120
Points
202
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
1helpful
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
3helpful
2answers
My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
1helpful
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
1helpful
Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
The printer requires attention. Try the following:
● If the printer is connected to a computer, check the computer screen for
instructions. If the printer is not connected to a computer, check for the following
problems:
– Top cover open
– Out of paper
– Paper jam
– Print carriage jammed or stuck
– Print cartridge inserted incorrectly
– Incorrect print cartridge installed
● If you are unable to solve the problem by using the instructions above, turn off the
printer and unplug the printer's power cord. Wait one minute, then plug it in again.
Turn on the printer.
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
How do you install ink into a hp c4180
Hi bogtank, here are the instruction on how to install the ink cartridges.
  1. Open print cartridge door, make sure the print carriage moves to the right, if it does not move to the right, turn the device off, then turn it back on again.
  2. Remove the tape from both cartridges, making sure you don't touch the copper coloured contacts.
  3. Hold the cartridge with the HP logo on top.
  4. Insert the tri-colour cartridge in the left cartridge slot, and the black cartridge in the right slot.
  5. Make sure you push the cartridges in firmly until they snap into place.
  6. Make sure you have paper loaded in the tray and close the print cartridge door.
  7. Press OK at the promt on the display to start print cartridge allignment.
  8. Check the display for status then press OK.
Print fragmented documnts
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
k24674
Grand Canyon Tech
Grand Canyon Tech
