Greetings,
Get a repairman to check and give you idea how much it will cost you. Then decide.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
DC (Adaptive Defrost Control) is **generally** the issue on
these....you can force a defrost by jumping L1 and Test on the board.
Some general info on how an automatic defrost works at:
http://www.applianceaid.com/defrost_cycle.html
Also, a little info on adaptive defrost controls at:
http://www.applianceaid.com/adaptive_defrost.html
Look in the freezer section, behind that rear panel for frost build up,
if you see frost build up, its a defrost issue, like the heater, timer
, defrost thermostat(bi-metal).
this will give you more info about cooling issues:
http://www.applianceaid.com/frig_notcold...
Thanks, Johnny,
We manually defrosted the fridge after finding the problem, but it has persisted even with an empty compartment. Does that suggest anything further?
I assume that I will have to open up the top of the fridge to get to the control board if necessary to test your solution?
Brian
