LG Flatron L1750S 17" LCD Monitor Logo
A
Anonymous Posted on Dec 16, 2010
Osd locked - LG Flatron L1750S 17" LCD Monitor
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Dec 16, 2010
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833716
Points
6040
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
1helpful
My computer says OSD locked , ive tryied every thing and nothing worked , HELP!!!!!!!!!! PLEASE
On screen display is locked. Fix it by:
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
7helpful
"OSD LOCKED" box on my screen
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
16helpful
2answers
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
1helpful
The brightness icon stays on my screen
May need to do this with if off (OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.)
3helpful
Osd locked , keeps flashing on screen
hi
vote me if you have your solution
Show "OSD Locked".in that cause i-Menu is not working. what i do?
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum…
6helpful
What to do to unblock osd lockout
You can download user manual here: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
See Page 54:
? OSD Lock — The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message "OSD Lock" displays for 10 seconds. ?If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD. ?If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Please leave good rating, thanks.
32helpful
2answers
MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I UNLOCK IT.
17helpful
3answers
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
6helpful
Compaq FP5315 monitor with OSD Lock out
Here is the tip to solve your problem. Hope this might be helpful to you.
OSD Lock—The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock” displays for five seconds.
❏If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
