The lid lock red light is always on when I do a load of washing on my Simpson eziset 7.5 top loader the ringing noise is always ringing the clothes do not spin at all now have you any answers for me
You machine may have lost a spring. I would recommend removing the back and place all bolts in a cup. Do not forget to unplug first. Then take a look at any thing out of place.
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Sorry but both require a service engineer's attention I suggest ;-0(
Good luck,
John C
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad! If this is the problem it could be the switching module or capacitor that needs replacing.
