The spark that you saw was probably caused by a cold solder ..remove the old solder,clean the pcb make sure that the track is still ok..if there is a break its ok to jump it with no.22 AWG solid copper wire.Some tv version gets the 24vdc supply for the vertical circuit from the flyback transformer.Also check the vertical IC for cold solders ..hope your problem is confined to cold solders only..good luck
