Appx 3 inches from the left of the screen and then on the far right side of the screen is a thin green line that runs from the top to the bottom of the screen. Is this something that can be fixed reasonably or do I just need to buy a new monitor?
Usually the case with this issue is the LCD panel itself. After a certain long period of time, some LCD panels just bug out and stop working. ( not sure why, possibly the way they were assembled and manufactured. For instance the LCD Panel has 8 connectors ((top)) and 3 connectors ((left)) (((Depends on model)))that attach to the main board of the LCD Panel, and on many occasions the thin lines wear and cut and therefore loosing part of your screen. If i explain further how it works i can write you a good explanation, just message me. That is the issue or the Cable connector from the Video Card to the LCD Panel is faulty. Try replacing that or the line will stay there for a long while then eventually your LCD display will begin to show more lines and eventualy Nebula itself. ( unusable )
You can also try repairing the LCD, in some rare cases the only problem when the line shows up is because of the video genesis card inside the FPD. try swapping that out with a known good one and perhaps that will work otherwise eventually the monitor will begin to stop working over time.
