The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
