30 amp tandem breaker or 2-30 amp cartridge or "Buss" screw-in plug fuses as this is the top amperage required for any household dryer rated up to 5,000 watts
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
That happened to mine I had to replace the "brain" of the washer....the part was about $170. I think it is called the control panel. There is a test you can run...look in the manual.
Check for a bad ground wire. Also while you are check the ground check all the other wires to make sure that they are seated properly and nothing has come lose or te wire plastic has come off or rubbed off and grounding itself out
Johan I think you can just plug it in & it will work ok you could try it if there' s a problem most likley it would blow the breaker of fuse. 220 would be less voltage so I don't think it would cause a problem. That's what I would do. I don't know what outlets they use over there might have to use a different plug on the power cord. Might want to check with someone over there but I think you can do that.
