Televison & Video Logo
A
Anonymous Posted on Dec 18, 2010
I cant program my uverse remote with my 32 inch emerson lcd tv.
Rofel Lantican
Level 3:
  • Master 2,632 Answers
  • Posted on Jan 24, 2011
Rofel Lantican
Master
Level 3:
Answers
2632
Questions
Helped
597108
Points
7882
To Manually program the AT&T universal remote control to your
TV here are the steps
Factory Reset the AT&T Remote Control:
* Press the ATT button and the OK button at the same time for 2-3 sec. release them at the same time. The ATT button will blink twice then enter the code 922. The ATT button will blink Thrice. IF not repeat the step
* Press the ATT button then check all the function of the remote (Volume, Channel, Menu, Guide)
Note: you will see that the max volume is 25. Dont worry its the volume of the receiver
To Program Your TV:
* Press the TV button and the OK button at the same time for 2-3 sec. release them at the same time. The TV button will blink twice then enter the code. Click Here to see the manucafturers list of codes. After Entering the code TV button will blink thrice. IF not repeat the step
Note: After you program the tv make sure to press the ATT button. then now check all the function of the remote. Follow the instruction and it will work. If you press the power button the TV and ATT Recievier will turn on and off at the same time
Thanks for using Fixya.
Anonymous
Level 3:
President:
  • Master 1,779 Answers
  • Posted on Dec 18, 2010
Anonymous
Master
Level 3:
President:
Answers
1779
Questions
Helped
578622
Points
5452
Try using the codes for Funai, Daewoo, all the low end China sets.
1helpful
2answers
Trying to program Uverse remote for Emerson 32 flat screen
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
Cannot get the uverse remote to program for my TV. TV is
hi! i have here a couple of codes for your sylvania tv, just try them, 1046, 1465, hope this helps!!! goodluck!!!
5helpful
2answers
Need remote code for emerson LC195emx LCD TV to program my uverse remote. ATT codes don't work. Thanks
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
2answers
I need to program my at&t uverse remote with the Emerson 19 inch TV/DVD. I do not have a code.
I need the code to program my EMerson LCD320EMXF for my ATT Uverse remote
hi! i have here a coiple of codes for your EMERSON TV. 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 you could try them. Hope it would help! Goodluck!!!
Just had at&t uverse installed the at&t wont turn the tv on or off and wont program
1helpful
2answers
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
2helpful
3answers
Programing Remote
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
2helpful
2answers
Ilo remote control code
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
