Buy a powered stage monitor and gonnect to the MON jack. You will select the channels to go to the monitor with the AUX knobs and the overall level with the MON slider.
Use BALANCED lines to the powered monitor... This is a TRS plug at the mixer end for sure...
REMEMBER to power ALL interconnected equipment from the same receptaacle or source, even if it means running an extension from where your speakers are plugged in to the mixer !!! The ground bounce between power receptacles within a building can destroy your equipment's sensitive input circuits.
