Hi, If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. check out this electric no heat tip... heatman101 ........
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Hi
Hi
Hi
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm Please get back to us if you have further query else please accept the suggestion.
Hi
Hi
