The lubricant has become sticky and is acting more like adhesive than lubricant. This is the most common cause of malfunction in the LS-2000 and LS-30 scanners. It's a quite curable condition.
Nikon LS-2000 and LS-30 film scanner service and repair is available. Check seller
pjferrante2 on eBay. Scanner performance backed for 12 months. Very
reasonable price.
SOURCE: Drivers for Nikon LS 5000-ED
Try these links:
http://www.silverfast.com/product/fr.html?product=436
http://www.xpvistasite.com/super_coolscan_5000_ed_13548.htm
'hope that helped.
SOURCE: Driver for Nikon LS 100 35 mm film scanner
you can download the file (NS163mac.sit) at http://www.nikon.co.kr/support/download/scanner/software/ns1/v163km.htm
It's the Korean Nikon website, just scroll down, look for NS163mac.sit in the middle of the page and click.
It is the Nikon Scan Version 1.63 for Nikon Scanners and will install Nikon Control 2.2 to scan the slides. We used it on a Power Mac 7500/100 with Mac OS 8.6.
Good luck.
Chris
SOURCE: how do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
SOURCE: scanning 110 negative film
I just finished scanning many 110 film strips. You need to lay the strip along the inside edge of slot A and scan in normal preview mode. On the preview strip, put a marquee around each individual photo and scan each one separately. Worked fine for me.
