Question about Roland Boss Dr670 Dr Rhythm W Bass Sounds
The unit is in excellent shape, not used much and has been kept in the oringinal box. I got it out today and the power won't come on? I put brand new batteries in it and still no power. It has been sitting in the box for a couple years though.
  • Roland Master
  • 5,603 Answers
Check for corrosion on battery contacts. If this unit can use an AC adapter, often the switch contact in the power plug that connects the batteries when adapter is removed gets bent and fails to connect the batteries.
Posted on Dec 19, 2010
Anonymous
SOURCE:
I have a Yamaha Electone HS-6 which for some reason won't power on anymore.. is there somewhere I can look at to get it fixed? where should I be looking at fixing this? Fuse? power box maybe?
Yamaha has a service locator at http://usa.yamaha.com/dealers/service_locator/ I ran it and it came up with the exact place local to me I would have taken it to. I know their reputation and have had service done by them before with excellent results. Your organ's a pretty complex unit, so if I were you, I'd take it to a Yamaha recommended facility, after checking with Yelp.
Jan 12, 2015 | Yamaha Music
Still Blowing fuses
there could be something wrong with moisture. I had a drink spilled down the back of mine and I had to clean the board cause it kept blowing fuses.
Aug 18, 2017 | JBL EON 515
Just bought. New b205d power is on but no sound
These are a nice unit... just bought three of them that were dead... I have repaired one so far. I assume you mean the blue LED is on indicating power is on. What I want you to test is if injecting signal on the BACK of the unit jack (power amp in) will create sound. If it won't then better exercise your warranty. The one unit I have completed repair had a bad 15 volt regulator in it... the second that is almost fixed somebody had blasted the input circuits... probably connected to a speaker output... don't do it... these are LINE and MIC level units. If you need to tap off a speaker output, use a DI box with the unit. The third unit I have not received yet. Drummer used the repaired one as monitor last night and was impressed with the power this unit has.
Jul 22, 2011 | Behringer Eurolive B205D Active 150-Watt...
What polarity is the input on the ion IED04 DIGITAL DRUM STAION BY ION. I HAD TO GET A POWER ADAPTER AND DON'T WANT TO DAMAGE UNIT. THERE IS NO PICTURE TO NOTE POLARITY.
There is NO POLARITY to worry about since you MUST use an adapter that supplies 9 volts AC at around 850ma. You CANNOT use a DC adapter with this unit and have it work. Putting a DC adapter of 9 volts on it won't damage it, it just won't work.
AC output adapters are harder to find.
Apr 14, 2011 | ION Audio iED04 Desktop Electronic Drum...
Hi , Just purchased an HD400 today . When powered up there is no menu screen available only black character blocks ?????
This sounds like a power supply problem. SInce the unit is brand new, exercise your warranty immediately. Don't mess with it and risk voiding the warranty.
If YOU supplied the power adapter, that is LIKELY the problem. This unit take one that is capable of 3 amps. (2.5 amps minimum) Most pedal adapters will NOT work with this unit as they don't have adequate current output.
Apr 12, 2011 | Line 6 POD HD400 Guitar Multi Effects...
I was playing my Orange Crush 20LDX that I just bought today and when I first plugged it in I could smell burning but I thought it wasn't that serious. After a while of playing, the amp still had power...
Since this is a brand new amp right out of the box, I would recommend returning it immediately to the dealer you bought it from. If it can't be repaired under warranty they might replace it with a new one.
Dec 18, 2010 | Orange Amps Orange Amplifiers Crush PiX...
Unfortunately, the correct action here is to return the unit for a replacement one. Any attempt to repair this will void the warranty. Since you just purchased this today, the store should not give you any trouble and just exchange the unit. If you need to, insist on an exchange rather than waste time on a warranty repair.
Good luck,
Dan
Peavey escort
I would try unplugging some of the extras. All of that could have been causing your line voltage to sag too low for the mixer supply to operate properly.
Jan 17, 2009 | Peavey 00511800 Escort Portable Sound...
Roland Boss Dr670 Dr Rhythm W Bass Sounds Logo
142 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Thomas F. Schneider
Are you a Roland Music Expert? Answer questions, earn points and help others
