Contributor
- Posted on Jul 03, 2008
Re: Bosch Nexxt 100 Series Washer
First check front filter for blockages if nothing found there check main hose from bottom of tub to filter for blockage if nothing found select either pump or drain listen fora light hum from pump area if this is so pump coil is faulty....then go to ure local parts supplier and geta pump coil
