Question about JVC AV-36020 TV
I lost my remote for my jvc 36" av-36020 my daughter still managed to lock the screen so all you see is a black box, we left the tv on before and it went away after a month then the power went out and it as been a black box ever sence any way i could fix this problem without the remote/ Thank- you
  • 675 Answers
The black screen you see is a closed captioning text box. you may be able to access the onscreeen menu from the front panel controls to shut off the captioning..If not , you may be able to obtain a universal replacement remote to access these features...If that does'nt work, then you will have to try to get an original remote
Posted on Dec 19, 2010
Testimonial: "Thank-You so much I cannot begin to explain my gratitude. I've been trying to figure that out for over a year now. Merry Christmas friend."
6ya staff
SOURCE:
JV AV36890 TV. My young daughter pressed buttons and managed to switch it from channels in the "A" set (ie A02, A03, A04...) to the B set- which has resulted in fuss and noise. Even the menu...
On your remote, push the input button, to change the input back to A. If that don't work, then unplug your set from the wall for 40min, and that will reset it back to normal.
Nov 22, 2010 | JVC AV-36890 36" TV
I have lost the remote and i cant get to tune in the channels, JVC AV-36D303 36" TV
use the button on the actual TV itself, they will do most of what the remote will do, you have menu, left, right, up down, enter./set, ON?OFF. They WILL be there somewhere...
May 02, 2010 | JVC AV-36D303 36" TV
A black box appears on the screen blocking the view. how do i get rid of it?
Turn off the TV's closed-captioning. It's set for "text" now and that's why the box sometimes shows up. Your remote control probably has a single button to control caption settings, and got pressed at some time. It's easy to do and confusing when it happens.
Hope this helps. Thanks for using Fixya!
Feb 22, 2010 | JVC AV-36D104 36" TV
Black box on top of picture
This sounds like the text function is turned on in the closed captioning part of the menu. If the remote has a separate captioning button press that until captioning and text are off. Otherwise the caption/text settings are in the customer menu. Go into the menu to the captioning options & shut captioning/text off and see if this corrects your problem.
Nov 09, 2009 | JVC AV-27D201 27" TV
I have a JVC model 36D501 TV and I have a large black box appearing on the screen....I think it's a pip problem, but I can't get pip to disengage....help
It is probably the closed captions on text mode.
look on the remote for a CC button or use the user menu to disengage the closed caption.
Mike
Jul 12, 2009 | JVC AV-36D303 36" TV
Big black square in the middle of tv screen
The clue is the black box, usually thats the close captioning box
Mar 08, 2009 | JVC AV-32D305 32" TV
Dog steps on remote and a black screen pops up in the middle of screen but you can see the picture on te outside of the black box. Jvc 32' d-series tv the remote is a jvc rm-c252
Sounds like a closed caption box or a pip box, if not try all the buttons on the remote one by one and lastly try to reset to factory settings if the option is present in menu settings.
Dec 21, 2008 | JVC AV-32S33 32" TV
The digital clock on my 30"JVC is showing in the bottom of screen
The menu screen does not function the display. Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes or more and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results. Reference the user guide below for the display button.
neww.gif JVC AV-36D503 36" TV - User Guide (page #43)
Dec 20, 2008 | JVC AV-36P902 36" TV
Green lock and black screen
go to your menu and turn off the ccd and text modes to remove the box,as for your lock out code try oooo or 9999.
Sep 22, 2008 | JVC AV-27D302 27" TV
Jvc d series tv
Take the closed caption (c.c) off on the remote and the black box will go away.
Feb 09, 2008 | JVC AV-27230 27" TV
JVC AV-36020 TV Logo
195 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
