SOURCE: white lines on screen
im sorry my friend I do not understand what a funny marrior is? LOL If your complaining about white lines at only the top of the picture, then I would say that your problem is with the vertical sweep circuit. Most likly a capacitor in the vertical preamp really small ones next to the jungle IC or the capacitors that are used as waveshapers in the vertical drive and output. If the entire screen is white lines then the screen drive is too high so back it down till the lines just disapear. if that wont turn down, theres a filter cap on the sweeop supply or the CRT socket board is bad. Good Luck
SOURCE: White lines accross top of screen on our 27 inch Toshiba,
My Toshiba required replacement of two of the vertical filters/capacitors. Doesn't take long and the parts are inexpensive, but requires a repairman.
SOURCE: Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
SOURCE: My Toshiba TV Model 27AF45 has white horizontal
go to the vertical section n change caps like 100uf, 2.2uf around the section in addtion check some caps in the line o/put like 22uf 250v
