Question about Maytag MAH2400A Front Load Washer
When I start my washer it starts to leak. pretty bad. It is not the connection points. It appears to me that the tears that are in the grey gasket/seal that is in the front of the washer has some holes and tears in it. Is this common? Is it something I need to replace entirely? kara
    Top Expert:
  • Maytag Master
  • 54,973 Answers
If the seal is torn, it will have to be replaced if you want to stop the leaking.
Posted on Feb 17, 2018
6ya staff
SOURCE:
Washer_tech
Geoff Siegel
  • 164 Answers
SOURCE: leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Posted on Dec 26, 2007
Anonymous
  • 1122 Answers
SOURCE: Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Posted on Oct 23, 2008
Frank
  • 90 Answers
SOURCE: water leaking from front door
The whole boot whould have to be replaced. Check if there are any visible cuts or if its somewhat worn around the lip. But i would change it out. I dont know of a quick fix that would work....
Posted on Jul 31, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Hole Rubbed in Bottom Door - Leaks Through Front
If you can get to it you can use an epoxy made for metal or something like jb weld to patch the holes.
Posted on Sep 22, 2009
milten1
milten1
  • 1304 Answers
SOURCE: Maytag washer MAH6500 leak - door boot issue?
there is a drain hole at the very bottom of the sump
about 1/4 in
if you ahve any other holes you will need a new boot
there is no real way to patch them, most patches will not flex enough to stay in place
ive included the part number you can order from sears
22003070
the best way to get one over on sears is to order it
then you cazn either fix it kinda hard but id walk you through it
or when the part arrives shedule service, just tell them its leaking
only when the tech gets there tell them you have a boot
sears hates self diagnostics and you will go to the bottom of the list
Posted on Oct 07, 2009
Water leaking from Bosch washer
Hi check the grey rubber seal around the door to the washer if there's a rip or tear if there is that would be the problem if not check pipes going to pump also water feed etc make sure all on and tight
Dec 23, 2013 | Bosch Axxis WAS24460UC 3.4 Cu. Ft. Front...
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
Leaking water under front edge of machine?
Open the door and gently pull on the grey rubber gasket and check all around it for holes / tears. There are three tiny holes in the 'wall' at the bottom that are supposed to be there, but you should not see any other tears. I just found a large tear on mine that causes leaks when I run very large loads. I am going to try to fix it with Gorilla Tape, otherwise I will probably have to buy the whole new gasket. It seems like it would be a real pain to replace!
Apr 30, 2010 | LG WM-2277HW Front Load Washer
Front door is leaking..I think there is gunk under the grey seal..can that be taken off and cleaned or anything?
If the door glass and the door seal are making proper contact there should not be a problem..The smallest gap, split or tear will let water out. A leaking door seal usually needs to be replaced by a tech....Nomess
Apr 02, 2010 | LG WM2487H Front Load Washer
Water leaking from below the tub. THe right shock
Yes it is the O-Ring part number 134146100 that is failing. I just had this happen on my washer. It involves a significant tear down of the machine. I have the service manual that I found on the internet showing how to tear it down. I am pretty sure I found it here on this site in fact.
Jan 17, 2010 | Frigidaire FTF530FS Front Load Washer
Washer leaking from underneath
MY FIRST THOUGHT WOULD BE INSPECT THE BIG GREY DOOR GASKET FOR A CUT OR A TEAR. LOOK CLOSE. THE WHOLE MAY BE TINY
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Dec 11, 2009 | Westinghouse Washing Machines
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
What causes the tears in the bellow seals on front loaded washers
It’s caused by gradual wear and tear through the vibration of the machine and rotation of the drum. If they are breaking down too often then it may be that your washing detergent mix or use of bleach or how you clean the bellows is weakening the rubber. Also excessive and heavy loads put more stress on the drum and can cause the drum to lurch dramatically from side to side which will end up in causing the bellows to wear / tear.
Oct 06, 2009 | Washing Machines
I have a kenmore washer that is leaking bad underneath in the front making puddles of water. Im constantly keeping towels down everytime I wash a load. Could you please tell me what might be wrong? Thank...
Check the front door boot first. Make sure that there are no tears in it.
Remove the back of the washer, start a fill cycle and observe outer tub sections and hoses for leaks. This is a good place to start.
Jan 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water Leakage Under Front Load Washer
most likley cause of your problem is the grey bellows has a tear in it. Inspect the bellows to check for tears. Or you can remove the lower panel and run the washer and look for the leak that way. Im sure it is a tear in the belows. Not a diffacult part to replace if you are mechanicly inclined. Good luck.
Nov 20, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH2400A Front Load Washer Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
