Fuji FinePix F10 Digital Camera Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I rotate pics I don't have the option to rotAte 45 degrees, it rotates 90
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Fuji Master 102,366 Answers
  • Posted on Jan 04, 2013
Fuji Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10431741
Points
622693
Correct. The camera lets you put the picture on its right side, on its left side, upside-down, or right-side up. It will NOT let you tilt the picture on a diagonal.
2 Related Answers
Anonymous
  • 423 Answers
  • Posted on Feb 18, 2008
SOURCE: finepix viewer movie clip rotation
video clips cannot be rotated. Don't shoot them in a vertical orientation, unless you want to rotate your monitor to accomodate them. Shoot video with the camera in horizontal orientation only.
Anonymous
  • Posted on Jan 19, 2010
SOURCE: I took a video with my finepix s5800 on vertical
You could use <a href="http:www.rotatevideo.org">rotatevideo.org</a> is a free online service. But you will have a bit of an quality loss when rotating a video.
Rotate screen
There are many ways.
With Intel HD Graphics Control Panel:
Rotate to 0 Degree: <Ctrl><Alt>Up arrow
Rotate to 90 Degree: <Ctrl><Alt>Left arrow
Rotate to 180 Degree: <Ctrl><Alt>Down arrow
Rotate to 270 Degree: <Ctrl><Alt>Right arrow
You can enter this Hot Keys panel by pressing:
<Ctrl><Alt>F6
Or right click on the desktop you will find:
Graphic Option. Click on it and in the expanded balloon,
Click "Rotation"
On monitor menu. This, I have no information. Couldn't find it on my Dell E2011H menu.
Hope this helps.
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
1helpful
Rotate screen back to normal
1helpful
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
My screen does not flip 180 degrees when i turn the screen around
2helpful
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Acer tablet troubleshooting
b>
2helpful
Change screen orientation
b>
1helpful
P c screen upsidedown
Hope this helps
1helpful
Monitor display is rotated 45 degrees. Can't get it back to normal.
right clik on the desktop and select graphic options then choose rotation. set to normal mode. fine ???
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
