It is not going to work. Both wifi and ethernet are for internet connection only. Ethernet is much faster than wifi. Also there is possibility to damage tv by plugging ethernet cable which is connected device using POE (power over ethernet). You need to connect your dvr via hdmi, component or composite cable
All WiFi "boxes", called WiFi routers, have a limited reach. That reach can be limited, when you are in a building with concrete walls and steel plating. But even when you have a free sight tot the router the range can be limited to 25 or 50 meters. Although manufactures say up to . Be aware other rower working on the same frequency, close to you also will limit the range of operation.
It depends on how far away you are from your wireless router, I have used the Chromecast and have found it to not have a very long range, if it is too far away it will be choppy. I would try moving it closer to the router.
This message means your extender is too far away from your wireless router to make a good connection. Repeaters must be within a good signal range for the connection to work properly.
If you have a wifi enabled phone, tablet, or laptop, you can walk around your home and see where the signal reaches and how well. Repeaters should be placed where you still receive full or close to full signal.
Repeaters may have issues if the wireless router is on another floor, behind metal, or too far away.
If possible move WiFi device into an open area central to your location. Microwaves can also cause interference and should be located far away from WiFi units. Also try changing your frequency channel plan.
