My cheap mouse is BROKEN! i neeed help NOW! the wire snapped and even if I tape it with electric tape and aligned the wire colors correctly it WONT WORK!!!!!! help!
You can try to strip a little bit of the jacket off the wires and twist them together securely. Then use a little bit of electrical tape to wrap the bare wire. After, you can tape the head piece back together...... or you could buy some new headphones.
Volkswagons regulator designs are weak in the support for so much weight. Its pivot points get worn then put alot of pressure on the motor. You may be able to get used better ones from a scrap yard but new ones from the dealership may have a garantee.
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
happened to me first time i bought them, but the ear was extended more so the break happened higher up on the extendor thing. I just taped it, and stuck it into the hole to stabalize it. About 3/4 of the life of my first skullcandys were spend broken. Then, somebody stole my backpack, took nothing out of it, and threw my skullcandys in the trash.
I sent in for a new pair, they've not broken for a much longer time but today, they have broken again. Because the break is much lower, the earpeice isnt held to my head and just dangles. Duct tape wont fix it so i'm gonna try hot glue. If that fails, i might sauter it.
Gaming mice are not cheap,sell for $30 - 130. The cord on my RAZER DIAMONDBACK mouse went bad, I opened the mouse & repaired the broken wires.You have to unplug cord from inside mouse,the connection plug has very small barbs,so you have to pry the socket open a bit to unplug it.Once the cord is out cut the rubber part on the cord that connects to mouse that reinforces the cord.Cut it off on both side,pull out the remaining bits of wire.You have to enlarge the hole in the rubber grommet to reinsert the cord threw it,a heated wire the size of the cord works well to enlarge the hole.Run cord thew grommet splice wires,solder wires if you have a soldering iron makes the best repair,splice wires offset from each other,so they are not all sliced at same location.Use a good tape to isulate the spliced area on each wire,about 1/2 of tape per splice,Scotch Super 33+ Premium Vinyl Electrical Tape. Once you have taped each wire, tape all the wires together, for better isulation.Reinslall wire harness & test mouse.
Make sure the product is turned on. The On button is lit when the product is on.
Lift the cartridge door. The carriage moves to the right side of the product.
Figure 12: Lift the cartridge door
Remove the new cartridge from its packaging and gently remove the plastic tape using the pink pull tab.
Figure 13: Remove the tape
CAUTION:
Slide the tri-color cartridge into the left slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place.
Figure 14: Insert the tri-color cartridge
Slide the black or photo cartridge into the right slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place.
Figure 15: Insert the black or photo cartridge
Close the cartridge door.
Step eleven: Align the cartridges
Make sure you have loaded plain white letter or A4 paper in the bottom tray. Press OK to print the alignment page.
Figure 16: Print the cartridge alignment page
Figure 17: Load the printed alignment page
Your best long term fix will be to solder the wires together then tape them individually and finally tape the whole thing. Second choice will be to use crimp (**** splice) connections and then tape. Last choice will be just twisting stripped wires together and tape everything.
Hellooo. 2 thing come to mind you may check. First check the ribbon cartridge to see if it is empty..These are usually a one time ribbon...and has to be replaced when empty. 2nd make sure the cartridge is snapped in properly and seated, and also the printwheel lever must be snapped (pushed forward) in order for everything to be aligned. if the typewriter has a correction tape (white or clear) make sure it is not interfering with the ribbon. Lastly the ribbon drive may be broken or out of adjustment. a minor repair. Hope this helps... Squipps
