My phone Nokia 5235 is showing "Phone Memory Full"..there is no option of file manager where I can view/delete extra files...while in the "application" folder I can view memory details...details as follows -
82 MB - memory in use
600 KB - free memory
5 B - calendar
191 KB - contact
2597 KB - messages
0 B - Images
0 B - sound clips
0 B - video clips
35 KB - documents
1468 KB - MIDP apps
15 MB SIS applications
62 MB - other files
phone memory should always be free... its the ram for your phone... you shoul keep all your files , applications and messages in memorycard ..... if memory in phone is low it will work slowly and you will not be able to open large sized applications in your phone
Kindly check the memory card as pictures are stored there and you can erase them from there. You can format the memory card from - go to Office Folder , File Manager choose Memory CArd and in options choose Format ( you will loose other data too ) or you can open memory card in file manager and delete the images folder .
If we are helpful kindly give us all thumbs up
Farhan
www.senseapplied.com
U delete ur data like calendar entries etc.. Aftr it u download netqin mobile guard.. By it u cn dlt ur all othr files.. If u want more info then contact me [email protected]
Hi, This problem Arises When your Phone memory(C:\ Drive) Is almost Full .normally C: Drive Has 44.4MB Space. But When it goes below 500KB,it shows "memory low delete some data" So delete unwanted files from phone memory using any Good File managers .One i suggest is Using "Xplore" An application for n73 Which can be downloaded Here
You can delete the phone memory files from the file manager or the files stored on the phone memory can be identified by a phone's icon and you can delete the files one by one..
Try to delete songs or setups that you might have kept in the phone memory (c:) drive of your phone ! and make sure no application is running in background before opening LifeBlog.
For better viewing of the files kept in the phone memory use X-PLORER software !
format your phone - but you will loose everything Otherwise go to memory details - go to applications and select options, scroll down to memory details and select phone memory. check how much u have used and what is free. Then delete accordingly - all your music files etc etc and bingo - now stop the tears
