Hi there
I haven't used my X50v for about 6 months and it won't turn on. I've been charging it for about 30 minutes now - the charge light is orange, but when I try to turn it on, nothing happens. I've tried a soft reset and that doesn't do anything either
Please help
Thanks!
Perform a hard reset.
1. Hold the reset button on the back.
2. Hold the Power button down.
3. Release the reset button.
4. Release the Power button.
5. Press the Contacts button when prompted.
Hope this helps!
Ken Akiyama
Don't forget to backup before performing a hard reset. Also, don't forget to check the lock button on the left side. Shamefully, that was my problem! I didn't even know the lock button was there, let alone that my purse demon locked it.
Later post Ken Akiyama had the correct solution. The hard reset did the trick.
But, you will loose your data and programs. Pays to backup.
Same problem and can't fix it.
Same. No solution. Throw it away...
Mine always worked fine until I left it on and it went to sleep. Now it will not turn on with fully charged battery or AC. When connected to computer via ActiveSync, will not accept input from touchscreen. When reset button is pushed, will not accept input from buttons to clear memory or cancel operations. It appears that all input methods died!
no dice
x50v was working for 2 weeks
3 fully charged batteries - so I highly doubt that I have 3 dead batteries (as one of these is even brand new)
I have the orange charging light come on and even the green fully charged light comes on...but thats it
tried to do both a soft and hard reset - with no results
Does anyone have any advice???
when i charge mine the light is red and it wont turn on i tried hard reset but it still does nothing help me please
i have dell axim x5 it does not turn on after several month without use.
Those resets do not work for me. It wont turn on!
