The internal memory is not the same as the memory card memory. The camera needs some elbowroom in the internal memory to work at all. It can't use the card memory while the internal memory is full. You need to delete some pictures from the internal memory, then insert the memory card, and it should work (assuming it is formatted correctly and is otherwise compatible).
