Roland HD1 V-Drum Lite Compact Electronic Drum Set Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Roland HD-1 V-Drums Lite kit - approximately 1.5 years old which now seems to be faulty. The drum pedals work properly and the snare and hi hat if you hit them very hard but the toms not at all. I wondered if this is a fault that you have come across before. I have tested the pads and they are working properly and I have tested the continuity of the cables all fine .The demos work fine and the sounds change from the numbers. Can you get a replacement board? What can I do next. Is it possible there is insufficient power from the adapter - although this was reading 9.5v. Paul - Northampton
gklohn
Level 2:
New Friend:
  • Expert 94 Answers
  • Posted on Dec 22, 2010
gklohn
Expert
Level 2:
New Friend:
Answers
94
Questions
0
Helped
22639
Points
136
TRY GIOVANIA FOR HELP.
I have a RMP-5 Rhythm Coach. I cannot get any sound from the pad when I practice. Help
Hi, after doing a bit of googling it occurs to me that the internal speaker is ONLY for the metronome / click & not for the drum sounds themselves. You will need headphones or some external audio gear like your hi-fi system or oth r amp & speaker. I found this "The pad has 54 sounds in it (covering all parts of the drum kit but mostly snares), which are triggered when you hit the mesh head, but these can only be heard over headphones. The built in speaker is only used by the metronome sound (when there are no headphones attached) and then it only has a beep sound attached to it. However, plug in headphones and you get a variety of available click sounds including a proper ticking clockwork metronome." Hope that helps a little? Good Luck :-)
tip
Studio Recording at Home; Part Deux
This tip, continuing the series of Home Studio Recording, focuses on the hardest part of accomplishing this feat: Drums.
A big sound killer on 'budget' recordings is poorly recorded drums. There is a remedy, though. If you have one set of drum mics, buy another (or borrow. This will come into play later, though).
If you have clips that hold them on the drums, great. With the two sets, you'll only use half of the clips. For the rest of the mics, you'll want stands. You'll need one stand for each drum, plus six.
The dual mics serve this purpose: To capture the sound of the whole drum. One mic for the batter head (the side you hit), and one for the resonator (the side you don't).
For the batter head, you'll use the mic clips, and attach the mics as you normally would during playing. For the resonator head, use the stands to position the mic directly across the drum, making a straight line from the top of the drum to the bottom. This will help eliminate any voicing differences, which can be a real headache.
For the bass drum, you'll need 2 stands. Position the batter head mic close to the edge of the head on whatever side is easiest to access, but is also comfortable for your playing style.
Aim the mic so that it is pointed at a midway point between the center of the head and the edge. You can experiment with different spots, but be sure to NEVER let the mic be directly in front of the head.
For the bass resonator head (the front one that everybody sees), position the mic so that it is a mirror image of the batter mic. Once again, this gets rid of voicing problems.
You have just miked your drum kit, but what about cymbals? That's where the other 4 mics and stands come into play. Those 4 will take care of:
Hi-hats
Ride
Overheads
For the hi-hats, you'll want to position the mic about 3-5 inches from the top, and 2-4 inches from the side. It's best to come in from the outside of the kit, so that you'll pick up a bit of ambiance (the rest of the kit, as well as some natural reverb). Point the mic at a point close to midway between the bell and edge of the hats. Too close to the edge, and you'll get a sound similar to banging trash can lids together. Too close to the bell, and there's too much high-mid noise that CANNOT be reduced with an EQ.
For the ride, follow the same instructions for the hi-hats, but add about 2 inches to the distances. Aim the mic a little closer to the center as well, so that the mic will pick up any bell hits. A good spot is 1/4 the distance between the bell and edge.
Now for overheads. These are the mics that not only record the cymbals, but pick up the most ambiance.
NOTICE: I haven't already mentioned it, but you do NOT want to record with the drum kit up against a wall, nor do you want it in the center of the room. For best results, use the midway rule (as with placing mics on drums and cymbals, place the kit midway between the center of the room and the edge, preferably headed towards a corner). This will reduce unwanted echoes in the room due to sound reflection.
You will want to place the overheads about 1.5 feet above the highest cymbal. Space them out so that the entire kit is between them, but be sure to keep them evenly spaced. You'll want to use the snare as a midway marker for the placement of overhead mics, since it is your loudest drum, and more likely to be picked up in the overheads than any other drum. This will also keep the snare panned center (you'll be panning the drums out to the left and right later on the mixer, but the snare and bass stay center).
These are some guidelines for setting up mics for recording drums at home. I hope that helps, and stay tuned for Part Trés of Home Studio Recording.
on Mar 13, 2011 • Music
1helpful
The snare triggers incorrectly
hello....just had the same proble... u probably need to clean or fix the port... (if u try to pull out just a little bit the jack u can see that everything it works properly).
I opened the snare (ccrew it out) , i cleaned the components with some spray and noweverything works.
let me know
ciao
I have a TD9KX and the problem i get is right in the centre of snare the sound seems to overload or is too sensitive. I cant get rid of this even when adjusting sensivity.
If the drum set is older, the cone that is in the center that transfers the hit to the piezo is degraded. You can find replacements on Ebay. You have to remove 4 screws to get the bridge under the snare out and then peel off the old cone from the piezo disk CAREFULLY and then stick new one on. The point of these goes bad. You will then want to adjust the height of the cone with the adjuster screws so it is barely, barely touching the drum head.
My Roland TD-6 Bass drum pedal spring has come off the Pedal. How do I put it baxck on?
There should be a nut and a cylindrical tightener at the bottom of the spring. If you loosen these, you should be able to pull the spring up and get the ring back onto the post. Then just tighten the nuts back down to where the tension feels right.
V-Drums don't all come with the same kick pedal--in fact they are often sold seperately--but this should be enough to help you with most basic kick pedal designs.
let me know if this doesn't make sense and tell me anything else you can about the pedal itself and I'll find a picture so I know what you have. This should work though. Good luck!
You can not play these drums live the spill of the fold back drum fill bin sets of the snare trigger ive turned down the sens on the red box still doesnt work a big waste of money i need to talk to...
With this kit being acoustic-electric, the only advice I can give is to disconnect your snare trigger and mic the snare. It's either that, or your snare trigger is faulty. A new trigger is going to cost about the same as mics, but mics won't hit your snare, making you sound inexperienced. For miking the snare, you'll want to get two mics, placed on the top and bottom head. Try to position them on the same spot on the rim to avoid voicing problems. Studio drummers do the same thing when recording.
For playing this way live, you'll want to use either the main PA, or run to a separate mixer so you can control the volume of the snare in relation to the rest of the kit.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
When i use my epro live drums on live gigs i sometimes get no sound when i hit the pads specialy the snare pad
Not used this kit inparticular, but if there is a main "brain" or sound mudule, check sensitivity settings. If not, take the pad to the store where you got it as the internal sensor may have gone, or the link lead may be faulty.
Seperate tracks
They have to be recorded on SEPERATE tracks if you want to keep them seperate. It will be hard to do this live as if you mic acoustics you will still get some cross feed in the mics from the different percussions.
With an electronic drum set it may be even harder as they often only have a single mixed output.
The way the professionals would do this is to play the kick and record it on a track... and then play that track back and record the snare and hat each seperately on other tracks.
Once you have synced tracks of the parts, then you can mix anyway you want.
With electronic drums you COULD have two seperate modules to give you two seperate outputs, but that is a budget breaker.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
