Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer will not spin when turned on. Drum spins by hand. Makes a buzzing noise and elecrtical (burning) smell. Dryer is unplugged now and vent is clear.
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 23, 2010
Anonymous
SOURCE:
My dryer stop working, it made a big noise and is not spining anymore, ts sounds as if it is out of place or something, and after 3 minutes it starts smelling like burn My dryer is a Maytag...
TRY SPINNING THE DRUM BY HAND. IF IT SPINS EASY, YOU HAVE A BELT BROKEN.
MOST LIKELY THE BANG WAS WHEN THE BELT BROKE. YOU NEED TO PULL THE DRYER OUT, OPEN IT UP AND REPLACE THE BELT. A SERVICE APPLIANCE REPAIR WILL NEED TO BE CALLED. - - SORRY
Feb 20, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
Maytag Neptune gas fired dryer motor does not turn makes buzzing sound
Dryers are turned by a belt, and belts break. You have to take the back off and look. The belt goes around the whole drum. It if broke, it will probably be on the bottom. Make sure the drum turns easily by hand. It could get jammed on something, or the bearing could go bad.
Sep 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer says 8.8. on display
Put a heating pad over the display panel. After 5 - 10 minutes, the display panel will return to normal and the dryer will work,
Jan 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Very Loud Dryer
squeeling hi pitch is usually the drum support roller above the heater. if you take the machine apart and turn all moving parts by hand you should be able to find the problem...if its a rumbling noise then it may be the blower wheel. UNPLUG FIRST..good luck :)
Jun 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer drum tries to start but won't
the start switch is probably bad on the motor but most dryers you have to buy the whole motor
Apr 24, 2009 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
212 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
