Durabrand DWT1304 13" TV Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Dec 20, 2010
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390722
Points
6614
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
2helpful
2answers
Need a remote. or need the universal codes to use another remote.
try 032 or 132 or 11034 or 694.
These have all worked on various remotes including Dish Network remotes for the Durabrand DWT 1304 color 13" TV. Look at the Funai Corp codes and the Orion codes. Sometimes they work, Funai Corp makes Durabrand.
Timrodlady
I misplaced manual for my 13 inch DWT 1304 and I need to set up tv for antenna reception in order to program my dtv converter box - in order for converter box to work, along with the indoor antenna, I have...
http://www.funai-corp.com/support/manuals.aspx
Click on link to download the manual for your tv.
Please rate this solution, the only compensation I receive is a good rating from you.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Will an RCA Digital Convertor work on Durabrands model #1304.?.
Hello chlpepr2,
Yes it should work, connect the RCA video out (yellow connector DTV Converter) to the RCA video in (yellow connector TV set). Then connect the RCA Audio out (Red-Right White-Left DTV converter) to the RCA audio in (Red-Right White-Left TV set).
Then setup your converter box according to the manufacture's instructions.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Is DTV converter box compatible with this set
how do u get cable ? now who form direct from wall cox cable charter or dish ?
1helpful
Dvd player
Try accessing the 'Game" mode from the Menu button on the TV. User Manual for Model DWT1304 is available online at http://funai-corp.com/support/manuals.aspx
4answers
Tv manual
Go to the manufacturers website. If all else fails...google it.
16helpful
7answers
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
1helpful
3answers
Owners Manual
Johstob...
For a Durabrand DWT 1304 Owners Manual, access TV Manuals Online here. You can easily download it. The manual is in .PDF format and showed exactly what I needed, how to delete a channel from the list.
I realize this query was posted a long time ago, but perhaps somebody else looking for the information will benefit from it/
Jim
2helpful
2answers
Connecting VCR/DVD
Does your TV have more than one A-V input ? If so perhaps you're plugged into the wrong input. Make sure you're coming out an output on your VCR/DVD player and going into an input A-V plug on your TV. Stargazer I've messed up like this a few times!
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
