PUT OUT PUT EQUALISER IN INPUT RETURN PUT IN PUT EQUALISER TO OUTPUT MIXER
OR JUST PUT EQUALISER BETWEEN MIXER AND AMPLIFIER MEAN OUT PUT EQALISER TO IN PUT AMPLIFIER AND INPUT OF MIXER TO OUT PUT OF MIXER
sounds like the cable from the gear stick to the gearbox selector switch has been put on wrong ,put the car into reverse so that the reverse light is on , turn the ignition off and find the gear selector on the gearbox , pop the end of the cable off it then put the gearstick into the "R" position and refit the end of the cable back onto the selector switch , hope this helps
You can put it in at the same time as you put the wash powder in before you start the wash but make sure you put it in the right compartment of the drawer.
put one on then go to the other side and put another on if you put one on next to the other one you will need to go around to other side and put one on there and so on
Not much on newer hogs but I'd guess if the spacers aren't the same length when you got the wheel on you'd see that the wheel isn't centered.Try again.Put the end thru the swing arm put on a spacer,push it thru the hub,put on the other spacer,push it thru swing arm put on washers and nut[loosely]and check the alaignment.Like I said I'm not much.
buy a pizza base...its readily available in d market.
put it in d microwave for 5 mins
then grate some mozzarella cheese and put on top of d pizza base...den put some vegetables...like capsicum, tomato, olives, etc..
again put it in microwave for 10 mins...
if needed den put again for some more time,
put some ketchup on top..
n ur pizza is ready
